Please see my answer there and provide the missing information.
Also, please don’t post the same thing on two plattforms, this binds double the time on our end and is unfair to other community users, as we could use that time better.
Hi, sorry I am new here. because I tried to follow the documentation of the installation in zammad.org but still I got the same error. maybe if you can send me the information that my installation is wrong or how can I resolve it alteast give me some idea. because If we will fix the error via our own in the code side we will have some trouble on the update side.
So I knew you are correct that maybe this is from the installation. but however in production.rb I enable the asset precompile, because before it is causing that the public assets cannot connect.
Again if you can help us since we are new in zammad, that will be helpful. and I am sorry community users if this eating lot of time for you to help us.
I am sorry, but we’re still missing the required information to be able to help you.
Firstly, please provide your webservers zone configuration, for whatever webserver you’re using.
This file contains the information on how the webserver is supposed to contact Zammad.
Also, step by step commands and output you receive might be helpfull, as you might have an issue at a place you don’t recognize it as one (which is perfectly fine).
Beside that, if you want to fiddle less, you could also use the package installation, because it’s a lot easier both in installation and handling during runtime.
