rake searchindex:rebuild is indexing zammad_production_*
rake searchindex:rebuild is indexing zammad_development_*
I moved my Zammad from one server to another. (same systems, but with elasticsearch V 7.13.1. instead of 7.10.2). Everything works fine, but my elasticsearch is always indexing the wrong name. I installed V 7.13.1.
Im running rake searchindex:rebuild. Everything went fine due the indexing. But it uses the developement database name. For exampe: zammad_development_user
But it should be zammad_production_user.
I tried to set it with this command: rails r “Setting.set(‘es_index’, ‘zammad_production’)”
But it only changes the first part part to zammad_production_development_user.
Where can i set it correct? To use the production name.
I restarted elasticsearch, after changes. I removed and installed the ingest-attachment plugin for elasticsearch. Using postgresql DBs.
