Following the instructions to install latest version of Zammad, running into a problem with Elasticsearch. I’ve installed, and verified that elasticsearch is running, but getting an error when trying to rebuild the search index.
curl -X GET 'http://localhost:9200'
"name" : "ticketing-server",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "nXYNjcN-Qy-1V4GP2d-ybA",
"version" : {
"number" : "7.17.21",
"build_flavor" : "default",
"build_type" : "deb",
"build_hash" : "d38e4b028f4a9784bb74de339ac1b877e2dbea6f",
"build_date" : "2024-04-26T04:36:26.745220156Z",
"build_snapshot" : false,
"lucene_version" : "8.11.3",
"minimum_wire_compatibility_version" : "6.8.0",
"minimum_index_compatibility_version" : "6.0.0-beta1"
"tagline" : "You Know, for Search"
This looks like elasticsearch is up and running, but when I run the command to rebuild I get an error about wrong SSL version number, as shown below.
The only step i wasn’t sure about was the setup of a username and password for elasticsearch, I don’t really know where to get these credentials from and the documentation for Zammad setup doesn’t elaborate.
zammad run rake zammad:searchindex:rebuild
rake aborted!
Unable to process GET request to elasticsearch URL 'https://localhost:9200'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fc1771156f8 @success=false, @body=nil, @data=nil, @code=0, @content_type=nil, @error="#<OpenSSL::SSL::SSLError: SSL_connect returned=1 errno=0 peeraddr=[::1]:9200 state=error: wrong version number>", @header=nil>
Payload:
null
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:36:in `info'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:64:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:492:in `exec'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:34:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:28:in `start'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/exe/bundle:37:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/exe/bundle:29:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
Tasks: TOP => zammad:searchindex:rebuild => zammad:searchindex:version_supported
