Used Zammad version: Version 6.3.1-1715932826.48881ba1.focal
Browser + version: Firefox 136.0.2
I would like to edit a group
I always get the error message “Missing required value for field ‘shared_drafts’!”. But the item is set to “active” - even if I set it to “inactive” it has no effect. When creating a new group everything is still ok, but when editing it no longer works.
I think I somehow deactivated the function with the drafts, but I just can’t find it anymore. Maybe that has something to do with it?
Sounds like you still have migrations that are pending. You can update all you want, missing database migrations will not magically heal themselves if something is blocking.
Execute the command I gave you earlier, it should give you a traceback.
