How can I delete old tickets by time hook when running zammad on docker-compose, i have searched for it but no results, hope to get some response
In Settings > Scheduler
you can set up a scheduler like this example:
That should do the job.
But be careful. Once deleted, you won’t be able to recover the tickets. Eventually test your scheduler first be addind a tag instead of deleting the ticket. That way you can check, if it does what you want it to do.
