is it possible that groups can be deleted in future releases?
Thank you in advance.
Best Regards.
Best Regards.
Hey Alexandra,
I don’t think so. For context, see this thread: Issue deleting Groups & Roles.
While there are ways to remove them manually, I wouldn’t risk it unless you really know what you’re doing.
I know that there is already a way to delete groups, but not over the ui.
It could made possible to delete groups, that are not needed anymore, over the ui, and block the deleting with a message, when there have to be made some changes in zammad, befor being able to delete the group.
