- Used Zammad version: 5.0.1
- Operating system: Debian 9
- Browser + version: Chrome and Firefox latest
- The datetime can be unset and stay like that throughout the entire ticket lifecycle.
- When I create a ticket and then go inside it, then the field with a datetime format automatically enters a date. See the screenshots for more detail. This has changed since I have updated to 5.0.1, before it worked as expected.
- Create a ticket object with the format datetime, then set all the options to only be shown, but not required.
- Create a ticket where the the created object with the datetime format is not set.
- Close the tab and open it again.
- You now have a date that is set and is required. If you want to close the tab, then you’re informed that the changes will be lost, although you haven’t made any change.
Here the object in the zammad console:
irb(main):001:0> ObjectManager::Attribute.find_by(name:“due_date”)
=> #<ObjectManager::Attribute id: 54, object_lookup_id: 2, name: “due_date”, display: “Fälligkeitsdatum”, data_type: “datetime”, data_option: {“future”=>true, “past”=>true, “diff”=>0, “default”=>nil, “null”=>true, “options”=>{}, “relation”=>""}, data_option_new: {}, editable: true, active: true, screens: {“create_middle”=>{“ticket.customer”=>{“shown”=>true, “required”=>false, “item_class”=>“column”}, “ticket.agent”=>{“shown”=>true, “required”=>false, “item_class”=>“column”}}, “edit”=>{“ticket.customer”=>{“shown”=>true, “required”=>false}, “ticket.agent”=>{“shown”=>true, “required”=>false}}}, to_create: false, to_migrate: false, to_delete: false, to_config: false, position: 1650, created_by_id: 3, updated_by_id: 47, created_at: “2021-03-15 15:52:31”, updated_at: “2021-12-06 15:51:03”>
Here the object in the web interface:
Here some Screenshots:
