- Used Zammad version: 3.3.0
- Used Zammad installation source: docker-compose
- Operating system: Debian
- Browser + version: FF
- Zammad usable normally
- Logging into Zammad is now possible and there is no more CSRF error.
Unfortunately, I can click on all menu items, but on the right side there is only “Loading”
I add the composer-override file so that you can quickly understand it.
It seems that he does not get the data that he wants to display in Admin under Settings. I can’t display a channel or users.
The CSRF error no longer occurs and I can log out and log in. But apparently eight tobacco here something else wrong?
I can also find nothing in the logs in the volume / var / libs / volumes / zammad-data. These are apparently not written.
- git clone https://github.com/zammad/zammad-docker-compose.git
- cd zammad-docker-compose
Here my Docker-Compose-override
version: ‘2’
services:
zammad-backup:
container_name: Zammad-Backup
zammad-elasticsearch:
container_name: Zammad-ElasticSearch
zammad-init:
container_name: Zammad-Init
zammad-memcached:
container_name: Zammad-MemCached
zammad-postgresql:
container_name: Zammad-PostgreSQL
zammad-railsserver:
container_name: Zammad-RailsServer
zammad-scheduler:
container_name: Zammad-Scheduler
zammad-websocket:
container_name: Zammad-WebSocket
zammad-nginx:
container_name: Zammad-NGINX
labels:
traefik.enable: true
# Routers
traefik.http.routers.zammad-nginx.rule: Host(`service.example.com`)
traefik.http.routers.zammad-nginx.entrypoints: websecure
traefik.http.routers.zammad-nginx.tls.certresolver: myresolver
traefik.http.routers.zammad-nginx.service: zammad_svc
traefik.http.services.zammad_svc.loadBalancer.server.port: 80
traefik.http.routers.zammad-nginx.middlewares: zammadHeader
traefik.http.middlewares.zammadHeader.headers.customrequestheaders.X-Forwarded-Proto: https
traefik.http.middlewares.zammadHeader.headers.customrequestheaders.X-Forwarded-Ssl: on
traefik.http.middlewares.zammadHeader.headers.customrequestheaders.X-Forwarded-Port: 443
traefik:
image: traefik:v2.1
container_name: Traefik
command:
- "--log.level=INFO"
- "--api"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.myresolver.acme.httpchallenge=true"
- "--certificatesresolvers.myresolver.acme.httpchallenge.entrypoint=web"
- "--certificatesresolvers.myresolver.acme.caserver=https://acme-v02.api.letsencrypt.org/directory"
- "--certificatesresolvers.myresolver.acme.email=infos@example.de"
- "--certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json"
ports:
- 80:80
- 443:443
volumes:
- ./letsencrypt:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
labels:
# Routers
traefik.http.routers.traefik.rule: Host(`traefik.example.de`)
traefik.http.routers.traefik.entrypoints: websecure
traefik.http.routers.traefik.service: api@internal
traefik.http.routers.traefik.tls.certresolver: myresolver
traefik.http.routers.traefik.middlewares: traefik-auth
# global redirect to https
traefik.http.routers.http-catchall.rule: hostregexp(`{host:.+}`)
traefik.http.routers.http-catchall.entrypoints: web
traefik.http.routers.http-catchall.middlewares: redirect-to-https
# Middleware
traefik.http.middlewares.traefik-auth.basicauth.removeheader: true
traefik.http.middlewares.traefik-auth.basicauth.users: csaeum:$$1$$X[kMyb^l$$Npy/uslnNuMB4pK0focS00
# middleware redirect
traefik.http.middlewares.redirect-to-https.redirectscheme.scheme: https
portainer:
image: portainer/portainer
container_name: Portainer
command: -H unix:///var/run/docker.sock
restart: always
volumes:
- portainer_data:/data
labels:
# Routers
traefik.http.routers.portainer.rule: Host(`portainer.example.de`)
traefik.http.routers.portainer.entrypoints: websecure
traefik.http.routers.portainer.tls.certresolver: myresolver
traefik.http.routers.portainer.service: portainer_svc
traefik.http.services.portainer_svc.loadBalancer.server.port: 9000
volumes:
portainer_data:
