Data Base in Zammad-Console using docker compose
Hello everyone,
I installed Zammad using Docker Compose. I’m trying to access the Zammad console via railsserver container using the command:
docker-compose exec zammad-railsserver rails c
Once I have access to the Zammad console, it seems that the database is not connected properly. When I try to check the number of User records using User.count, it returns 0.
I’ve also attempted to run database migrations using the command:
docker-compose exec zammad-railsserver rake db:migrate
However, this hasn’t resolved the issue.
Can anyone help me identify what might be causing this problem?
Thank you for your assistance.
Duplicate of How can I use zammad console on docker-compose - #3 by sina and V6.0.0 Zammad-rails return empty values
Please be a little bit patient. This is a free community without any gurantees. Bumping or creating several topics of the same nature won’t speed up matters.
