My issue was up for at least a week, and the only time someone from Zammad officially comments is when I find a solution that works that’s nto to their liking, instead of actually suggesting ways to fix the broken upgrade.
As I mentioned initially, yes, I followed the update instructions exactly, and lots of things broke, but no solution was forthcoming from anyone.
So I found my own solution which works.
The upgrade on Debian 10 did NOT certainly work and had many issues. And I tried various things to fix it and made it worse, including some of your suggestion.
Upgrading to Debian 11 fixed all the issues, and, after doing some research on various forums, including Stack Overflow, the above solution that I posted is what works.
Someone even posted the same issue that I had on your Git instance as an Issue, and it was closed down as saying it was a technical problem, not a bug. But if multiple people are having the same issue, then it is a bug that needs fixing, as something is definitely going wrong with the upgrade for the packaged version on Debian 10.
We have it working now using the above-posted method, and that’s all that matters right now as I have a bunch of other things to work on, including learning how Core Workflows work because the official documentation on it is very lacking in detail, so I don’t have time to downgrade back to Debian 10 and Zammad 4.0 to try something that I know will not work.
So, instead of reprimanding and shaming, how about providing some actual technical assistance and suggest solutions that actually fix the things the upgrade breaks on Debian 10 for those that experience the same issues I did/
Also, saying unattended upgrades are not to be performed goes against all automation and efficiency protocols.
