I tried try and error and i always got - in the URL and never #{organization.customfield}-value.
Any way to generate a URL without an input-field?
Currently i use a trigger + select to set an value and get a link.
My idea is to provide search and create issue link. I added project ID as custom field to organization and #{ticket.title}. Most parts working as expected.
Any idea for or a hack to get something like that to work. Would be really great or i need to add them by hand to the select and a trigger. I don’t think i’m the only one that is interested in links with an organization attribute.
I think we’re talking from two different things:
Your organization attribtue can be retreived via variable, but only if it’s not using the linking template.
Using two linking objects in a row (while referencing one) will not work.
