Description:
I have integrated the live chat code given me on my zammad instance located at support.domain.tld and put on my website at domain.tld. Both websites have a ssl certificate and I am using https.
Problem:
Now when I want to open my website the widget isn’t showing up. I am online as agent but the chat isn’t showing up, I get the message
WebSocket connection to 'wss://domain.tld/ws' failed: Error during WebSocket handshake: Unexpected response code: 404
Here I was wondering why domian.tld is showing up as my zammad instance is located at support.domain.tld.
My Nginx .conf:
upstream zammad-railsserver {
server 127.0.0.1:3000;
upstream zammad-websocket {
server 127.0.0.1:6042;
server {
server_name support.domain.tld;
server_tokens off;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/support.simple-crypto.net/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/support.simple-crypto.net/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = support.simple-crypto.net) {
} # managed by Certbot
listen 80;
server_name support.simple-crypto.net;
return 404; # managed by Certbot
