Hi ! How can I change a language in notifications mail ?
Change the language setting of the affected agent and you’re good to go. That is as long as there’s a notification translation.
Thanks but I changed the language to French in zammad settings but in the customer’s inclination notifications arrive in English
You’re talking about triggers which are, at no point, affected by language settings.
You might want to take a look at the following doc:
https://admin-docs.zammad.org/en/latest/manage/trigger.html
It’s work thank you so much
