Used Zammad version: 3.6
Used Zammad installation source: deb repository
Operating system: Debian 9.13
Browser + version: Firefox
Customize Login Web Interfaces
Good Morning, is it possible to customize login web interfaces?
I would like delete the sentences attacched. Is it possible?
How can i delete that sentence?
Thank You
I would like translate closed successful in my language or create another ticket status.
Is it possible?
awedor
December 31, 2020, 7:50am
#3
Completely deleting this section will not be so easy but you could just go in to the translation section and change the sentence to s.th. completely different, maybe that helps? If you want to make design changes to the site you will have to work with a custom css file.
Thank You for your answer…
Where can I find the s.th in the translation section?
Thank You
Okkk I have found the correct section and i have modified…
Thank You
system
closed
May 7, 2021, 11:06am
#6
