is it possible to remove the dependency with Zammad to use Mysql charsets when Mariadb is installed?
Error: Transaction test error:
file /usr/share/mysql/charsets/Index.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/armscii8.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/ascii.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp1250.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp1251.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp1256.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp1257.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp850.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp852.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/cp866.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/dec8.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/geostd8.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/greek.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/hebrew.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/hp8.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/keybcs2.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/koi8r.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/koi8u.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/latin1.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/latin2.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/latin5.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/latin7.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/macce.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/macroman.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
file /usr/share/mysql/charsets/swe7.xml conflicts between attempted installs of mysql-common-8.0.21-1.module+el8.2.0+7793+cfe2b687.x86_64 and MariaDB-common-10.5.10-1.el8.x86_64
Upgrading:
MariaDB-client x86_64 10.5.10-1.el8 mariadb-main 13 M
MariaDB-common x86_64 10.5.10-1.el8 mariadb-main 87 k
MariaDB-server x86_64 10.5.10-1.el8 mariadb-main 27 M
MariaDB-shared x86_64 10.5.10-1.el8 mariadb-main 115 k
galera-4 x86_64 26.4.8-1.el8 mariadb-main 13 M
guile x86_64 5:2.0.14-7.0.1.el8 ol8_appstream 3.5 M
zammad x86_64 4.0.0-1620717869.89595964.centos8 zammad 124 M
Installing dependencies:
mysql-common x86_64 8.0.21-1.module+el8.2.0+7793+cfe2b687 ol8_appstream 148 k
mysql-libs x86_64 8.0.21-1.module+el8.2.0+7793+cfe2b687 ol8_appstream 1.4 M
