- Used Zammad version: 5.0.x
- Operating system: Ubuntu 20.04.3 LTS
- Browser + version: Firefox 94.0
I wanna change the colors of admin UI so I added a custom css to /var/lib/docker/volumes/zammad-docker-compose_zammad-data/_data/app/assets/stylesheets/custom/custom.css.
I know that the next step is to compile the assets. Using Portainer, I executed the command rails r rake assets:precompile
- assets should compile
- Traceback (most recent call last):
33: from bin/rails:9:in<main>' 32: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in
require’
31: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:inrequire_with_bootsnap_lfi' 30: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in
register’
29: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:inblock in require_with_bootsnap_lfi' 28: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in
require’
27: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/commands.rb:18:in<main>' 26: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/command.rb:46:in
invoke’
25: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/command/base.rb:69:inperform' 24: from /usr/local/bundle/gems/thor-1.1.0/lib/thor.rb:392:in
dispatch’
23: from /usr/local/bundle/gems/thor-1.1.0/lib/thor/invocation.rb:127:ininvoke_command' 22: from /usr/local/bundle/gems/thor-1.1.0/lib/thor/command.rb:27:in
run’
21: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/commands/runner/runner_command.rb:33:inperform' 20: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/command/actions.rb:14:in
require_application_and_environment!’
19: from /usr/local/bundle/gems/railties-6.0.4.1/lib/rails/command/actions.rb:22:inrequire_application!' 18: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in
require’
17: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:inrequire_with_bootsnap_lfi' 16: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in
register’
15: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:inblock in require_with_bootsnap_lfi' 14: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in
require’
13: from /opt/zammad/config/application.rb:19:in<main>' 12: from /opt/zammad/config/application.rb:19:in
select’
11: from /opt/zammad/config/application.rb:20:inblock in <main>' 10: from /usr/local/bundle/gems/activesupport-6.0.4.1/lib/active_support/dependencies.rb:324:in
require’
9: from /usr/local/bundle/gems/activesupport-6.0.4.1/lib/active_support/dependencies.rb:291:inload_dependency' 8: from /usr/local/bundle/gems/activesupport-6.0.4.1/lib/active_support/dependencies.rb:324:in
block in require’
7: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:inrequire' 6: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in
require_with_bootsnap_lfi’
5: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:inregister' 4: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in
block in require_with_bootsnap_lfi’
3: from /usr/local/bundle/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:inrequire' 2: from /usr/local/bundle/gems/execjs-2.8.1/lib/execjs.rb:4:in
1: from /usr/local/bundle/gems/execjs-2.8.1/lib/execjs.rb:5:in<module:ExecJS>' /usr/local/bundle/gems/execjs-2.8.1/lib/execjs/runtimes.rb:58:in
autodetect’: Could not find a JavaScript runtime. See GitHub - rails/execjs: Run JavaScript code from Ruby for a list of available runtimes. (ExecJS::RuntimeUnavailable)
zammad@74ea63969404:~$ ls
CHANGELOG.md Gemfile Guardfile LICENSE-3RD-PARTY.txt Procfile README.md VERSION bin config contrib gulpfile.js log public tmp
CREDITS Gemfile.lock LICENSE LICENSE-ICONS-3RD-PARTY.json Procfile.frontend Rakefile app browserlist config.ru db lib package.json script vendor
zammad@74ea63969404:~$ cd bin
zammad@74ea63969404:~/bin$ ls
bundle rails rake rspec setup spring update yarn
zammad@74ea63969404:~/bin$ rails r rake assets:precompile
require’
register’
require’
invoke’
dispatch’
run’
require’
register’
require’
select’
require’
block in require’
- Install zammad using docker-compose
- execute the command rails r rake assets:precompile on the rails container
Is there any way to precompile assets in docker-compose setup? Thanks
