- Used Zammad version: 2.8
- Used Zammad installation source: deb
- Operating system: ubuntu 18.04
- Browser + version: any
can log in same credentials after update and upgrade
Cant login
- Working zammad 2.8
- sudo systemctl stop zammad
- apt update
- apt upgrade
restart system/machine then still cant login after update from 2.8 version
ANY ADVICE HOW CAN I UPGRADE SMOOTHLY THANK YOU
also tried run db:migrate below are the error
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedTable: ERROR: relation “active_job_locks” does not exist
LINE 8: WHERE a.attrelid = ‘“active_job_locks”’::regc…
: SELECT a.attname, format_type(a.atttypid, a.atttypmod),
pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod,
c.collname, col_description(a.attrelid, a.attnum) AS comment
FROM pg_attribute a
LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum
LEFT JOIN pg_type t ON a.atttypid = t.oid
LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation
WHERE a.attrelid = ‘“active_job_locks”’::regclass
AND a.attnum > 0 AND NOT a.attisdropped
ORDER BY a.attnum
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:63:in async_exec' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:63:in
block (2 levels) in query’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/dependencies/interlock.rb:48:in block in permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/concurrency/share_lock.rb:187:in
yield_shares’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/dependencies/interlock.rb:47:in permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:62:in
block in query’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:581:in block (2 levels) in log' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:580:in
block in log’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/notifications/instrumenter.rb:23:in instrument' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:571:in
log’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:61:in query' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/postgresql_adapter.rb:757:in
column_definitions’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:113:in columns' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/schema_cache.rb:69:in
columns’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/schema_cache.rb:75:in columns_hash' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/model_schema.rb:466:in
load_schema!’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/attributes.rb:234:in load_schema!' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/attribute_decorators.rb:51:in
load_schema!’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/model_schema.rb:459:in block in load_schema' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/model_schema.rb:456:in
load_schema’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/model_schema.rb:346:in attribute_types' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/model_schema.rb:370:in
type_for_attribute’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/table_metadata.rb:33:in type' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:51:in
build’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:112:in block in expand_from_hash' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:71:in
each’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:71:in flat_map' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:71:in
expand_from_hash’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/predicate_builder.rb:21:in build_from_hash' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/where_clause_factory.rb:19:in
build’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/query_methods.rb:588:in where!' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/query_methods.rb:581:in
where’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/finder_methods.rb:81:in find_by' /opt/zammad/app/jobs/concerns/has_active_job_lock.rb:117:in
active_job_lock’
/opt/zammad/app/jobs/concerns/has_active_job_lock.rb:107:in active_job_lock_for_enqueue!' /opt/zammad/app/jobs/concerns/has_active_job_lock.rb:58:in
block in ensure_active_job_lock_for_enqueue!’
/opt/zammad/app/jobs/concerns/has_active_job_lock.rb:90:in block in in_active_job_lock_transaction' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:267:in
block in transaction’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in block in within_new_transaction' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in
within_new_transaction’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:267:in transaction' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/transactions.rb:212:in
transaction’
/opt/zammad/app/jobs/concerns/has_active_job_lock.rb:89:in in_active_job_lock_transaction' /opt/zammad/app/jobs/concerns/has_active_job_lock.rb:57:in
/opt/zammad/app/jobs/concerns/has_active_job_lock.rb:6:in block (2 levels) in <module:HasActiveJobLock>' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:426:in
instance_exec’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:426:in block in make_lambda' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:198:in
block (2 levels) in halting’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:606:in block (2 levels) in default_terminator' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:605:in
catch’
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:605:in block in default_terminator' /opt/zammad/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.4.1/lib/active_support/callbacks.rb:199:in
block in halting’
Thank you
