Used Zammad installation source: Through command line using yum and rpm
Operating system: centos7
Browser + version: Firefox and chrome
I should take remote of zammad using localhost:80 with the use of nginx
Zammad is running in my local machine, but i cannot take remote using localhost:80 since am using nginx as my webserver
I have configured the localhost name in server_name in the zammad.conf file in conf.d . But still cannot take remote of zammad .It is still showing the test page of nginx in the remote system.
Yup I got an error , Something like can’t find favicon.io not found and then i fixed it by adding “log_not_found = off” in Site-availability and added the symlink in nginx.conf
Just I replaced the localhost with my IP:3000 , Is there anything to be done apart from this
Please revert the upstream-server parts back to “localhost[…]”.
Take a look onto the server directive, there’s a comment above server_name stating the following
So you have to change server_name localhost; on the following line
