Can Zammad be used as a single user system running on localhost?
New user here. I have been using my personal gmail account as a support desk for over 2 decades now, but due to some new requirements, I asked chatGPT to suggest a helpdesk ticketing system and Zammad came up on the list.
My ticket volumes are very low - about 100-200 tickets a year. And I won’t be exposing the Zammad instance on the web for external customers to log in and submit tickets. They continue to operate as they have done before - by sending a mail to my gmail account.
My system details:
MacBook laptop running Tahoe 26.6.2 (25G83), Apple M2, 24GB RAM
Safari browser (Version 26.6.2 (21624.5.1.11.3))
Zammad docker version (7.2.0-8e542da2.docker)
Can Zammad be used as a single user system with only the admin account for support? All other users in the system will be customers, but they won’t have access to Zammad instance. I start up Zammad on my browser using localhost:.
In this scenario, my steps are as follows:
  • I create the admin account (I skip the email channel setup during admin setup phase)
  • I import all my customers as users
  • I disable all notifications and alerts
  • I try to setup my gmail as an email channel using App Password for authentication. I know Zammad suggests using Google OAuth, but I prefer to use the App Password for now.
But the last step is failing with email validation error. I know the credentials are correct because after I fill in the Inbound IMAP section using Expert mode (and set Helpdesk as my fetch folder, not INBOX), it pops up a screen saying n messages were found in Helpdesk and I can use Archive Import to process them. I select a date for Archive mode and press continue. Then I fill in SMTP details in the Outbound section. It tries to validate by sending a test mail. That mail never arrives in Gmail Inbox or Helpdesk and I can’t find anything in Sent folder either. So it’s not even getting to the point of sending mail.
After it fails, when it comes back to the Email channel landing page, I see the Notifications section filled in with my Gmail outbound details and to the right, it has another email listed that simply says noreply@localhost. I am unable to delete this record.
So my question is: can I run Zammad as a single user system using localhost? If yes, what am I doing wrong? Just to eliminate the Helpdesk folder selection as an issue, I tried setting up a brand new Yahoo account as an email channel using INBOX as the default folder (by leaving the Folder blank), and even that setup continues to fail validation. Nothing in Inbox, nothing in Sent. There are no errors I can see in the docker container zammad-railsserver logs either. I see some info about the parameters it is using for inbound and outbound and they seem consistent with what I have entered.
I have been struggling with this for days now, so can someone help? With no email channel setup, I have been unable to process even a single ticket.
Cheers.
Technically? Yes, absolutely. As long as you can run e.g. docker-compose or other docker based stacks, the guest system doesn’t matter at all.
The question would rather be, if this makes sense at all. Because of Zammads hardware requirements, while your device being well in the speck, it’s not the only thing you run on the machine.
It’s also questionable if a ticket system makes sense in a classic way for a single user - that highly depends on what you want to do. If it is just about emailing, then a normal mail program usually is still good enough (for a single user).
Ok that’s good to know I can run on localhost.
I was happy using gmail as my support desk until some recent regulatory developments compelled me to look at a ticketing system to manage audit trails. Hence the need beyond an email system.
In my interaction with chatGPT, it was evident that Zammad is going to be resource heavy and may not be right for a single user, low volume system. But in my experiments with other apps, I found that my requirements were not being met in importing historical service records:
  • I am looking for a solution that maps one gmail conversation into exactly one ticket. Other apps I looked at, simply end up creating one ticket for each message.
  • When I import my gmails, I found other apps don’t retain the timestamps from the conversation boundaries. Instead they simply import everything as today’s tickets. According to chatGPT, Zammad can retain original timestamps when importing in Archive Mode, hence my interest in this app.
  • Ability to import from a specified folder instead of default INBOX.
  • Ability to have multiple emails mapped to a single user. Zammad doesn’t allow this, but using Manage Filters, I was able to setup rules to map multiple emails of the same user against the default email registered in Zammad. I have not been able to test this because my email channel setup isn’t working.
  • When importing from gmail, if the conversation was initiated by me and if there was no response from the customer, other apps were tagging me as the ticket owner, instead of the customer I wrote to. I found a setting in Zammad that allows me to set the first customer in the From list to be the owner. Again, I haven’t been able to test this.
So, if I can technically use Zammad as a single user, localhost instance, what am I doing wrong with the setup I have. chatGPT and I tried debugging this and one suggestion was to change FQDN from localhost to gmail.com and also change the Notification Sender pattern (in Ticket Setting, I think) to hardcode my gmail address there. But that didn’t work either.
Anything else I can try would be greatly appreciated.
Thank you.
