- Used Zammad version: 3.3.x
- Used Zammad installation source: (source, package, …) package
- Operating system: Centos7
- Browser + version: firefox 75.x
- my fqdn works
- I am using a private ip 10.x.x.x and my fqdn : mydomaine.x.x.x
*I’am testing locally using hosts file
*Now zammad works fine with my ip adresse
the error DNS_PROBE_FINISHED_NXDOMAIN keep appearing I understand that is a dns problem where is the problem?
This is my hosts file:
10.x.x.x mydomaine.x.x.x mydomaine
This is nginx file:
upstream zammad-railsserver {
server 127.0.0.1:3000;
upstream zammad-websocket {
server 127.0.0.1:6042;
server {
listen 80;
server_name mydomaine.x.x.x;
server_tokens off;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
Ps: I a have restarted nginx after updating the config file
