Can a KB category be turned "Not visible"?
v.5.0.x
Let’s say I have a category of many articles that are only relevant at specific times of year.
Is there a method to set visibility of a category to “Not visible”?
Or do I have to go in one by one to turn off visibility? Pretty tedious.
As a follow up to that, are there any granular abilities to let one/more Organization see a Category of KB articles?
Say for example I’m supporting an org/dept with specific needs that may even have some semi-private info or confusing info… and I only want an specific org/dept to be able to see the Category or KBs.
Is this possible?
I’m afraid you’ll have to go the one by one method.
You can’t overrule category visibility - it always depends on the existing articles below.
Granular knowledgebase permissions are currently not supported by Zammad but on the improvement list. ETA unknown though.
