- Used Zammad version: 2.3.0
- Installation method (source, package, …): via RPM based on this description https://docs.zammad.org/en/latest/install-centos.html
- Operating system: clean install of CentOS on Hyper-V (Server 2012R2) based on this description
https://www.altaro.com/hyper-v/centos-linux-hyper-v/ - Database + version: the one that comes Wirth the RPM
- Elasticsearch version: the one that comes Wirth the RPM
- Browser + version: Safari Version 11.1 (13605.1.27.2.1) Java 8 Build161 enabled
Loading Helpdesk
When I try to reach the Helpdesk via the local IP of the Zammad installation (192.168.178.79) it shows a blank page with “Loading…” in the upper left corner and nothing happens.
My zammad.conf File (/etc/nginx/conf.d/) looks like this:
upstream zammad-railsserver {
server localhost:3000;
upstream zammad-websocket {
server localhost:6042;
server {
listen 80;
server_name 192.168.178.79
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_types text/plain text/xml text/css image/svg+xml application/javascript application/x- javascript application/json application/xml;
gzip_proxied any;
