Is the overall search function for tickets working for you? Sounds rather strange.
Not at all and I guess something with elasticsearch is broken. Does the autocomplete use elasticsearch, too?
I got an issue I found on several pages in the net but never found a solution.
Unable to process PUT request to elasticsearch URL 'http://localhost:9200/zammad_production'.
but elasticsearch is running and answers
# curl -X GET 'http://localhost:9200'
"name" : "AgswWxg",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "p4EWtdvPRGye-SXIaxqwdg",
"version" : {
"number" : "5.5.3",
"build_hash" : "9305a5e",
"build_date" : "2017-09-07T15:56:59.599Z",
"build_snapshot" : false,
"lucene_version" : "6.6.0"
"tagline" : "You Know, for Search"
Disabling elasticsearch (the workaround in most of the posts I found about this) worked for me, too. Search and autocomplete now works, but I guess this is not the way it should be solved.
thanks in advance!
Hey no worries, I’m sure we’ll get that fixed.
Please follow the instructions on the following page:
https://docs.zammad.org/en/latest/install-elasticsearch.html
Make sure that your elasticsearch does not get newer than 5.6 (but that’s fitting on your end so all good)
Lemme know if that helped.
Thanks
That install howto is what I did, I followed the Debian 9 steps but could not get any connection to elasticsearch. Tried different ports, localhost and 127.0.0.1, etc.
My elasticsearch package is already pinned to 5.4.3
Could you please post the history and output of what you do while during that? Maybe we’ll find the error then
system
closed
December 1, 2018, 8:42am
#7
