just a few beginners questions before beginning…
Is it possible to assign incoming tickets based on rules?
Let’s say for the following example:
if body contains “Lady Gaga” or “Madonna” assign group “pop”
if body contains “Johannes Sebastian Bach” assign group “classic”
in any other case keep it unassigned
Or assign a customer number?
if sender is found in address book/LDAP/whatever assign customer number refering to address book
Or to topics…
if customer number is categorized as VIP and body contains “urgent” do a defined “priority” action?
Note that Zammad does not check LDAP addressbooks.
If however a user attribute of your ldap object does contain a specific information that you synchronize with Zammad (which it by default does hourly) it can check on specific attribute values if needed during the runtime of a scheduler or trigger.
