Just wanted to ask a quick question. Is it possible to auto close (seems you can) but then forward the ticket to a external mailbox?
The idea is to add another mailbox like feature_request@example.com then forward the email another mailbox like developers@example.com but keep the ticket number from zammad as a reference of the request?
I am new the Zammad. What i seen is that i can create trigger that where the state is open to execute a state close on the object. What i can not figure out is the forwarding. I choose email notification, but i do not understand how i can enter an email address to forward to?
Create an agent for the dev-guys with their E-Mail-address, tell the trigger to assign the ticket to agent “Dev”, to close the ticket and send the notification E-Mail to “Owner”.
You need to utilize an designated agent user instead of a group. Then you can build a trigger to assign the tickets to this user and send a notify mail to him (as he became the ticket owner).
You want to do something like the following. What I saw when I tried working on that I noticed that there seems to be no variable that I can take in order to get the latest entry text. But I got no time to check on that right now.
Thank you that triggers the forward email! works just like it should. I found the reason it does not forward. The outbound notification master email address (that i can not change) is being blocked by the SMTP server i am using. Wil fix it using postfix and email address re-writes.
Thank you very much for your assistance sir, really appreciate the assistance!
