Hi, I’m running zammad 2.4.x from the docker-compose github repo.
In the Overviews section, any view, so let’s use /#ticket/view/all_open as the example.
I select a few tickets by clicking the checkbox and the bulk action toolbar at the bottom appears,
I can select different state, priority and group, however the owner selector only has one option, “-” .
Oh, I just had a thought, does it only show people in the agent role? I wasn’t using the agent role, it was empty, but I added some users in and it didn’t change anything.
Select the group (even if it’s the same and you don’t want to change it) and then take a look into the assigne option. It’s a bit confusing, wanted to write something as enhancement for this behavior later (just forgot it)
