- Used Zammad version: 5.x
- Operating system: CentOS 7
precompile work after install nodejs12 based on zammad help in following url:
https://docs.zammad.org/en/latest/install/package.html#optional-node-js
zammad run rake assets:precompile
error stylelint@14.1.0: The engine “node” is incompatible with this module. Expected version “^12.20.0 || ^14.13.1 || >=16.0.0”. Got “12.16.2”
error Found incompatible module.
info Visit yarn install | Yarn for documentation about this command.
rake aborted!
Based on zammad help,
Nodejs12 is installed correctly.
Node -v
v12.22.5
yarn -v
1.22.17
npm -v
8.5.4
Sorry about that. You may want to upgrade to v14 or better.
Documentation update will come some when after my vacation.
Yes please.
Enjoy your vacation wishes.
This issue confused me.
I tried
nodejs 14.13.3
nodejs 12.20.0
nodejs 16.0.0
Same result and still get
yarn install v1.22.17
[1/4] Resolving packages…
[2/4] Fetching packages…
rake aborted!
I noticed reason of issue. Its not relate to nodejs or yarn.
I will report it soon here.
Can you tell us all the reason for the issue, please?
And do you have a solution?
Even with node v16, I am getting the same error. I tried this from /home/zammad and from /opt/zammad:
root@server /home/zammad # zammad run rake assets:precompile
yarn install v1.22.18
root@server /home/zammad # yarn -v
1.22.18
root@server /home/zammad # node -v
v16.14.1
Yes, Sure.
I am using a custom font in my zammad , I add nwa-font.css to /opt/zammad/app/assets/stylesheets/custom
with following details
@font-face {
font-family: “IranSans”;
src: url("./fonts/IRANSansWeb.eot?#") format(“eot”), url("./fonts/IRANSansWeb.woff") format(“woff”), url("./fonts/IRANSansWeb.ttf") format(“truetype”);
font-family: "IranSansNum";
src: url("./fonts/IRANSansWeb(FaNum).ttf") format("truetype");
body {
font-family: “IranSansNum”,“Tahoma” !important;
zammad run rake assets:precompile working fine with this modification on zammad 4.x but on zammad 5.x return error and rake aborted!
I don’t know why?! Maybe zammad team guys can help.
Although i must say with or without the custom css, Following essage showing but if i remove the css, assets:precompile will work fine and precompile other modifications.
Update : Same results on Zammad 5.1.0
