Articles of type fax are not visible in frontend. In a email filter we change the type of incoming emails form our fax server to type fax. The mails are deleted from the email inbox, but there are no tickets in the system. At least it is not possible to find those in the normal search.
Same filter works if type is set to phone.
Used Zammad version: 3.2
Operating system: Debian Linux
Browser + version: Chrome
Tickets of type fax are visible in the system
Tickets are not visible
Create a email filter rule matching on a given criteria e.g. Sender = fax@xyz.com
Set filter action to Type = Fax
Send a mail matching the given criteria to the ticket system
Ensure that your overviews are showing the searched tickets.
If they don’t, try searching for e.g. the sender via search function.
If you still can’t find the issue, you proberbly don’t have any access rights on the group the fax mails go to.
Even though Zammad doesn’t let you select article type “fax” when writing new articles, I don’t see a reason why tickets should vanish (expecting you’re not closing them right away or even deleting / ignoring them via filter).
Ok, I found an error message. It is not related to the type = fax but related to the email as such:
I, [2020-01-22T16:56:00.735208 #1-47431584164680] INFO – : - message 8/29,
/usr/local/bundle/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in block in create_with_logging_context', "ERROR: Can't process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/595d9c9c81cdf1af7d11592c61d6e4d4.eml, please create an issue at https://github.com/zammad/zammad/issues", "ERROR: #<NoMethodError: undefined methodmatch?’ for nil:NilClass>",
E, [2020-01-22T16:56:01.071489 #1-47431584164680] ERROR – : ERROR: Can’t process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/595d9c9c81cdf1af7d11592c61d6e4d4.eml, please create an issue at https://github.com/zammad/zammad/issues,
E, [2020-01-22T16:56:01.071527 #1-47431584164680] ERROR – : undefined method match?' for nil:NilClass (NoMethodError), /opt/zammad/app/models/channel/email_parser.rb:737:inblock in get_attachments’
