API, Ticket search for not filled objects
  • Used Zammad version: 3.1
Can I search for objects that are not filled with the api? Like this:
https://[servername]/api/v1/tickets/search?query=[object name]:NULL&limit=2
I don’t find something, that show an example for this.
Thanks
Yes, if you use nil instead of null you should be good to go.
Even with nil it doesn’t work for me.
https://[servername]/api/v1/tickets/search?query=[object name]:?query=github:NIL&limit=2
https://[servername]/api/v1/tickets/search?query=github:nil
Works just fine.
ok, we have now solved it differently.
