Title: Allow additional data to be fed into External Data Source Fields
Currently, the only data that can be fed into an External Data Source Field Object’s Search URL is the search.term. Other data such as the customer details, organization or other object data are not accessible at that point. -
This means that in order to filter External Data, variables have to be hard-coded into the Search URL. -
This data does not appear to be available during ticket creation. So either multiple objects are required, or external methods need to be used to intercept and inject this information. -
Ideally, any ticket/user data (within reason) should be available to feed into the external data query.
This would allow a single Object to be used that automatically filters it’s options based on the current customer, or what the customer has previously selected.
Your Zammad environment:
- Average concurrent agent count: 60
- Average tickets a day: 400
- What roles/people are involved: IT Support and Site teams supporting 19 schools
In our specific environment, an example use case would be that natively, in order to provide a dropdown list of students, we currently require 19 objects and 19 core workflows to ensure that a teacher can find the right student. This, combined with the fact that External Data Source Field Objects are currently single-select only, means that we end up needing hundreds of objects and workflows, just to provide a simple, secure and accurate form to add 30 students to an exam group.
As mentioned, external methods to intercept and inject this information is technically possible. I have done this, and have a working system, that grabs the current customer email address and the organization (if the customer has at least one secondary org) and adds this data to the search URL. I’ve written two separate versions, as the new Desktop View functions differently to the current legacy web interface. This is not a long-term solution, as we need to be able to update Zammad without worrying about it breaking my bodges.
Legacy UI version;
(function() {
console.log("Zammad Interceptor v9 (Agent UI + Payload Scraper) loaded.");
let checkJquery = setInterval(function() {
if (window.jQuery) {
clearInterval(checkJquery);
window.jQuery.ajaxPrefilter(function(options, originalOptions, jqXHR) {
if (options.url && options.url.indexOf('external_data_source') !== -1) {
try {
let smuggledPrefix = "";
// --- 1. AGENT VIEW: Check Customer Information Sidebar ---
let agentCustomerEmail = "";
document.querySelectorAll('.sidebar-content .sidebar-block').forEach(block => {
let label = block.querySelector('label');
if (label && label.innerText.trim() === 'Email') {
// Extract the raw text nodes inside the block (ignoring the label itself)
let textNodes = Array.from(block.childNodes).filter(node => node.nodeType === Node.TEXT_NODE);
let emailText = textNodes.map(n => n.nodeValue.trim()).join('');
if (emailText.includes('@swale.at')) {
agentCustomerEmail = emailText;
if (agentCustomerEmail) {
// Smuggle the customer's username!
smuggledPrefix = "USER:" + agentCustomerEmail.split('@')[0];
// --- 2. CUSTOMER VIEW: Check Org Dropdown ---
else {
const orgInput = document.querySelector('div[data-attribute-name="organization_id"] input.searchableSelect-main');
let currentOrg = orgInput ? (orgInput.getAttribute('title') || orgInput.value || "").trim() : "";
if (currentOrg) {
smuggledPrefix = "ORG:" + currentOrg;
// --- 3. CUSTOMER VIEW: Check Profile Avatar ---
else {
const profileAvatar = document.querySelector('a[href="#current_user"]');
if (profileAvatar) {
let email = profileAvatar.getAttribute('title') || "";
if (email && email.includes('@swale.at')) {
smuggledPrefix = "USER:" + email.split('@')[0];
// --- 4. Inject into the jQuery Data Payload ---
if (smuggledPrefix) {
if (options.data && typeof options.data === 'string') {
let params = new URLSearchParams(options.data);
let currentQuery = params.get('query') || '';
if (!currentQuery.includes('||')) {
params.set('query', smuggledPrefix + '||' + currentQuery);
options.data = params.toString();
console.log("Interceptor: Smuggled perfectly ->", options.data);
} catch (e) {
console.error("Interceptor Error:", e);
}, 100);
