After i-doit upgrade integration not works
Dear Support Team,
We recently updated i-doit CMDB to version 25, api 1.14.1, since that i-doit integration does not work - cant add CI from CMDB through Zammad.
The error message what i can see in the admin interface (system>integrations>i-doit)
i-doit system error: Please specify a user by RPC Session header or HTTP Basic Authentication.",“data”:null}}
Was worked with the previous version of i-doit.
  • Used Zammad version: This is Zammad version 5.0.x (
  • Operating system: Ubunto 20.x
  • Browser + version: edge
It can connect to i-doit to select / add CI from cmdb via API
It can not connect to i-doit to select / add CI from cmdb via API
Do you have any idea what’s went wrong there?
Thanks
David
Hi @naveumag. You should update your Zammad instance first, it’s running a very old version that is prone to security risks.
Thanks, will do and let you know the outcome.
One mor question: what is the recommended version to upgrade from my current version?
Can you please copypaste here what is the procedure to follow during the upgrade?
Many thanks
David
Here we go: Updating Zammad — Zammad documentation
