Add "target group" to M365 channel configuration BEFORE the first import
    When adding a M365 mailbox with existing mails, I want to decide what group the tickets should be created in.
    When adding a M365 mailbox with existing mails, I have tickets created in the wrong group.
    For M365 channels you can only select the target group AFTER adding the channel.
    A similar behaviour to “classic” email channel, where you can choose the target group while setting up the connection details.
