To often select the same email recipients quickly. e.g. like contactgroups in microsoft outlook - Which are one or two concrete situations where this problem hurts the most?
to send mails to specific usergroups repeatedly - Why is it not solvable with the Zammad standard?
Support said isnt - What is your expectation/what do you want to achieve?
see 1
The templates are mandatory. Please use them, we didn’t set them up because we were bored.
Ive added the questions… better?
The template looks like so.
Title: <Short but meaningful description of the feature>
Your Zammad environment:
* Average concurrent agent count:
* Average tickets a day:
* What roles/people are involved:
Thank you and have fun.
Hi, ik how the template looks and Ive used it. I just dont think the missing infos would benefit anything on this clear FR as everyone knows outlook.
Or does this help you?
- Average concurrent agent count: 10
- Average tickets a day: idk 20?
- What roles/people are involved: IT-department uses zammad and writes internally or to other departments
I dont have more Infos than that. Just writing this as my workcollege was missing the feature he loves in outlook and support said its indeed not in zammad yet and I should write it here. Now Ive put enough time in this
Yes that helps to understand the scope of your request. Thanks.
Will you remove that missing-template tag now or isnt that important?
(Like for me as an outsider it looks like thats an ignore-this-request-tag, could be wrong).
Thanks
I think on many answers from my end (and possibly behaviors) people see and know that I’m not one of the subtile persons. If I have a problem, I communicate it without flowers. A tag would reflect that.
Apart from that, while we are busy, we are evaluating every feature request before denying it (we have a category for that) or consider it further.
Alright thank you for that explanation and remove of the tag!
