AD-Attributes in Zammad-Signature?
  • Used Zammad version: 6.0
  • Used Zammad installation type: APT
Hi there,
we wan’t to customize the dynamic signature for our agents with some more Information. The Agents/Users are authenticated by Azure AD.
If i use “::”, when i edit a signature, there are no attributes listed, for example, for the User-Title (like “IT-Expert”, “CEO”, etc.).
Also, if i use the following variables:
#{user.address}
#{user.mobile}
#{user.fax}
#{user.phone}
#{user.vip}
I get this output, when i answer a ticket as agent:
+4xxxxxxxxxxxx
false
So some attributes seems not to be synced from AzureAD to the Zammad-Userdatabase.
Is it possible to fix this? Or maybe to add other attributes, like the User-Title (CEO, CTO, …)?
Thanks in advance!
Hi there,
i got it working. I had already an unused LDAP-Connection; we used it, before we setup the AzureAD-Auth.
I added some custom objects and updated the LDAP-sync, were i can link AD-attributes to the custom objects; and then i used them in the signature.
