Gives:
=> Booting Puma
=> Rails 5.1.4 application starting in production
=> Run rails server -h
for more startup options
Exiting
bundler: failed to load command: script/rails (script/rails)
TypeError: Mapping is not a module
/opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:6:in <module:FolderContact>' /opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:5:in
module:Exchange’
/opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:4:in <module:Import>' /opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:3:in
class:Unit’
/opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:2:in <class:Sequencer>' /opt/zammad/lib/sequencer/unit/import/exchange/folder_contact/mapping/login.rb:1:in
<top (required)>’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in require' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in
block in require’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:258:in load_dependency' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in
require’
/opt/zammad/lib/mixin/required_sub_paths.rb:35:in block in eager_load_recursive' /opt/zammad/lib/mixin/required_sub_paths.rb:26:in
each’
/opt/zammad/lib/mixin/required_sub_paths.rb:26:in eager_load_recursive' /opt/zammad/lib/mixin/required_sub_paths.rb:40:in
block in eager_load_recursive’
/opt/zammad/lib/mixin/required_sub_paths.rb:39:in each' /opt/zammad/lib/mixin/required_sub_paths.rb:39:in
/opt/zammad/lib/mixin/required_sub_paths.rb:40:in block in eager_load_recursive' /opt/zammad/lib/mixin/required_sub_paths.rb:39:in
each’
/opt/zammad/lib/mixin/required_sub_paths.rb:39:in eager_load_recursive' /opt/zammad/lib/mixin/required_sub_paths.rb:40:in
each’
/opt/zammad/lib/mixin/required_sub_paths.rb:39:in eager_load_recursive' /opt/zammad/lib/mixin/required_sub_paths.rb:7:in
included’
/opt/zammad/lib/sequencer/unit.rb:5:in include' /opt/zammad/lib/sequencer/unit.rb:5:in
class:Unit’
/opt/zammad/lib/sequencer/unit.rb:4:in <class:Sequencer>' /opt/zammad/lib/sequencer/unit.rb:3:in
<top (required)>’
block in require’
require’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:379:in block in require_or_load' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:36:in
block in load_interlock’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:12:in block in loading' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/concurrency/share_lock.rb:149:in
exclusive’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:11:in loading' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:36:in
load_interlock’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:357:in require_or_load' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:335:in
depend_on’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:251:in require_dependency' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:476:in
block (2 levels) in eager_load!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:475:in each' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:475:in
block in eager_load!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:473:in each' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:473:in
eager_load!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:354:in eager_load!' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application/finisher.rb:67:in
each’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application/finisher.rb:67:in block in <module:Finisher>' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in
instance_exec’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in run' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:59:in
block in run_initializers’
/opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:228:in block in tsort_each' /opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:350:in
block (2 levels) in each_strongly_connected_component’
/opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:431:in each_strongly_connected_component_from' /opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:349:in
block in each_strongly_connected_component’
/opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:347:in each' /opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:347:in
call’
/opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:347:in each_strongly_connected_component' /opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:226:in
tsort_each’
/opt/zammad/vendor/ruby-2.4.2/lib/ruby/2.4.0/tsort.rb:205:in tsort_each' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:58:in
run_initializers’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:353:in initialize!' /opt/zammad/config/environment.rb:5:in
<top (required)>’
block in require’
require’
config.ru:3:in block in <main>' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/builder.rb:55:in
instance_eval’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/builder.rb:55:in initialize' config.ru:in
new’
config.ru:in <main>' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/builder.rb:49:in
eval’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/builder.rb:49:in new_from_string' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/builder.rb:40:in
parse_file’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/server.rb:319:in build_app_and_options_from_config' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/server.rb:219:in
app’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/server/server_command.rb:24:in app' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/server.rb:354:in
wrapped_app’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/server.rb:283:in start' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/server/server_command.rb:44:in
start’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/server/server_command.rb:135:in block in perform' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/server/server_command.rb:130:in
tap’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands/server/server_command.rb:130:in perform' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.0/lib/thor/command.rb:27:in
run’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.0/lib/thor/invocation.rb:126:in invoke_command' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.0/lib/thor.rb:387:in
dispatch’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/command/base.rb:63:in perform' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/command.rb:44:in
invoke’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/commands.rb:16:in <top (required)>' script/rails:6:in
require’
script/rails:6:in `<top (required)>’
Intermediate I try to restore the globale backup from yesterday hoping that this will help…
